    My 53/54 Chevy/Gmc build
    Tommy2tone
    Tommy2tone
    My 53/54 Chevy/Gmc build Empty My 53/54 Chevy/Gmc build
    Post  Tommy2tone Mon Aug 30, 2010 6:09 pm
    Bought this already started project in May. It is a 54 Gmc Cab with 53 Chevy fenders, grille and hood on a 92 GMC Sonoma frame.
    My 53/54 Chevy/Gmc build Truck2
    The previous owner had run all new brake lines, welded in the patch panels and set up steering and clutch brake pedals. First thing I did was get rid of the 4 cylinder engine and remove his body mounts and lower the cab and POR 15 the frame. Put in a SBC but used the T5 tranny that came with the truck. Had to cut down the input shaft to fit the old bell housing.
    My 53/54 Chevy/Gmc build 4cyl
    My 53/54 Chevy/Gmc build Cab
    My 53/54 Chevy/Gmc build Transmount1
    Welded in new motor mounts and made the tranny mount. Finished the body work on the cab and put that back on the frame.
    My 53/54 Chevy/Gmc build Backprimer
    My 53/54 Chevy/Gmc build Frontprimer
    We have cut down the bed side panels to 50 inches and shortened the frame. Also have to narrow the bed.
    Yesterday my 2 sons made the clutch linkage and welded that in. Something is not right in the tranny. When you step on the pedal the fork will not move. I must have put something together wrong. Have to take it all apart again. Seems like these builds are 1 step forward and 5 back. I ordered a cam for the engine and that arrived broken in half. Went to Advance auto and asked for a Holley 650 cfm carb for a spread bore manifold. Got it home and went to install it and it was a square bore carb and they didn't have a spread bore in stock so I had to order 1 from Jegs. Now I have all the right parts to do the engine.
    My 53/54 Chevy/Gmc build Empty Re: My 53/54 Chevy/Gmc build
    Post  Darkside Dave Tue Aug 31, 2010 9:01 am
    Hi Tommy,
    Man oh Man... It sounds like you are having your fair share of trouble with that one. The first picture you have there looks like the stuff you get is as bad as what I start with. However, it looks as though in spite of all the setbacks, you are making progress. I gotta wonder, how does a delivery service break a cam in half??? BTW, since this is a build thread I made it a sticky.
    Tommy2tone
    Tommy2tone
    Post  Tommy2tone Tue Sep 07, 2010 8:16 pm
    Pulled the tranny and saw that the fork was not riding on the ball. I must have pushed the throw out bearing all the way into the fork so that when we put the tranny in it pulled the fork off the ball. By having the throw out bearing in so far it would not allow it to swivel on the fork. Thats why everything was bound up. In a way it was good that this happened as not being a mechanic and being in a hurry putting this together I never bothered checking the condition of the bearing and now discovered it will not turn so I will replace that before putting it back together.
    Post  Darkside Dave Tue Sep 07, 2010 10:11 pm
    Yep, whenever I pull a manual tranny I always put in a new throw out bearing. It's the best and cheapest time to do it.
    Tommy2tone
    Tommy2tone
    Post  Tommy2tone Tue Oct 05, 2010 7:33 pm
    Well I finally got my sons to help put the tranny back in. Appears the clutch is working properly but I have one problem. When you step on the pedal there only seems to be only about 2 inches of movement. We raised the rod to the fork up 1 hole and was a little better but it is still not right. Do I have to go with a shorter rod from the pedal or longer? Or do I have to shorten the rod that goes to the fork? Help please.
    Post  Darkside Dave Tue Oct 05, 2010 9:01 pm
    Tommy2tone wrote:Well I finally got my sons to help put the tranny back in. Appears the clutch is working properly but I have one problem. When you step on the pedal there only seems to be only about 2 inches of movement. We raised the rod to the fork up 1 hole and was a little better but it is still not right. Do I have to go with a shorter rod from the pedal or longer? Or do I have to shorten the rod that goes to the fork? Help please.
    Hi Tommy,
    I would have to see some pictures of what you have to work with before I made a suggestion.
    Tommy2tone
    Tommy2tone
    Post  Tommy2tone Wed Nov 03, 2010 8:10 am
    Well I had to put the project on hold until spring because we are leaving tomorrow for Florida for the winter.
    Post  Darkside Dave Wed Nov 03, 2010 9:27 pm
    I would rather work on the truck than go to Florida...
      Current date/time is Wed May 01, 2024 5:41 pm
