    suspension geometry
    suspension geometry Empty suspension geometry
    Post  Grumpyoldman Sat Dec 26, 2009 5:32 pm
    THE PRIMARY PURPOSE OF THIS SITE
    While this site contains pages of interest to the road racer and oval track racer, the primary focus is on the safety and performance problems inherent with the car most commonly in competition at the world's dragstrips: A rear wheel drive vehicle with a beam rear axle.
    These problems arise from the the manner in which the driveshaft reaction torque is distributed and/or canceled by the suspension geometry. This determines the relative loadings of both the front and rear tires, and, consequently, the ultimate safety and performance of the car.
    http://www.racetec.cc/shope/index.htm
    Kaptn' Obvious
    Kaptn' Obvious
    suspension geometry Empty Re: suspension geometry
    Post  Kaptn' Obvious Sat Jun 05, 2010 2:35 am
    Pretty cool, if you run into anything IRS and RWD related I'd love to see it...
    Kaptn' Obvious
    Kaptn' Obvious
    Post  Kaptn' Obvious Sat Jun 05, 2010 5:24 am
    4am brainfarts...
    As a novice welder from what I understand TIG and MIG and Plasma need about the same power source. Modulated DC power.
    Why not throw an EDM head into the mix? An EDM head would require a DI bottle and a pump, and a spiffy head to go with it, but you could burn through a broken bolt or tap like butter.
      Current date/time is Fri Apr 26, 2024 5:30 am
