i`m back, didn`t work on my truck at all this summer just to damn busy,anyway got my tank done this weekend and i figured i`d post it up, first of all bought a 69 mustang tank off e-bay (cheepest around) cut the fuel pump and vent bung off the crown vic tank, measured and marked a hole where the tank is completely flat at the bottom and cut a hole on top of the tank with a holesaw,didn`t have the proper size so i just cut out the hole to the proper size, was initially going to build a fuel tray like tanks ink are using to mount on my fuel pump but decided to build a sump and baffle (don`t want the pump to ever starv out) figured out my sump would stick out one inch lower than my tank and a 2 1/2 wall or baffle inside the tank, proceded and bent and welded my sump,(kinda looks like a ashtray) ,drilled 6 holes just over the 1 inch mark so fuel can go into it (front and front sides only), 1/4 inch from the top curled in the edges,on the front and front sides,centered it in the pump hole of the tank, marked and cut the bottom of the tank out,GRIND THE TANK STEEL TO REMOVE GALVANIZED COATING BEFORE WELDING) welded in the sump, inside and outside of the tank, welded in the bungs, fuel pump was sitting sideways from the bung mount, cut the mounting bracket off and added a piece of steel and welded it together to make it straight and also the proper length from the bottom of the tank to the top, so now all i have to do is line the inside of the tank and its done!! going to use kreem tank liner.
