    steel bender on the cheap
    steel bender on the cheap Empty steel bender on the cheap
    Post  charger Mon Jun 15, 2009 3:21 pm
    needed a bigger bender to bend some steel on my truck,bender i built is 5ft wide, basically found some 1/4 inch by 2 1/2 inch angle iron laying around the shop, went to the local hardware store and bought a hd piano hinge, drilled holes in angle one and 3 in the diagram, used steel pop rivets and riveted the hinge to angle 1 and 3, angle no 2 rounded off the edge drilled and installed bolts through the end of angle 2 and 1, welded 2 square stubs at the end of agle 1,took 2 pieces of steel tubing,drilled a hole into it, welded a nut to the tube ,installed a bolt, this then fits over the stubs i previously welded (makes unit more compact)welded a piece of tubing at angle three to install a handle and basically your done! if you have to bend smaller metal instead of uning the clamp down bolts i use a c-clamp,i basically made this as easy as possible and cheap because time is something i don`t have! hope this helps somebody in the future! Darn can`t get diagram to download, will try later!
    https://i.servimg.com/u/f61/14/01/27/98/pictur12.jpg
    steel bender on the cheap Pictur13
    steel bender on the cheap Pictur14
    steel bender on the cheap Pictur15
    steel bender on the cheap Pictur16
    steel bender on the cheap Empty Re: steel bender on the cheap
    Post  Darkside Dave Mon Jun 15, 2009 6:41 pm
    Hi Charger,
    That's cool. Glad to se you have jumped right in and started posting.
      Similar topics
      Current date/time is Fri Apr 26, 2024 2:13 pm
