Bought this already started project in May. It is a 54 Gmc Cab with 53 Chevy fenders, grille and hood on a 92 GMC Sonoma frame.
The previous owner had run all new brake lines, welded in the patch panels and set up steering and clutch brake pedals. First thing I did was get rid of the 4 cylinder engine and remove his body mounts and lower the cab and POR 15 the frame. Put in a SBC but used the T5 tranny that came with the truck. Had to cut down the input shaft to fit the old bell housing.
Welded in new motor mounts and made the tranny mount. Finished the body work on the cab and put that back on the frame.
We have cut down the bed side panels to 50 inches and shortened the frame. Also have to narrow the bed.
Yesterday my 2 sons made the clutch linkage and welded that in. Something is not right in the tranny. When you step on the pedal the fork will not move. I must have put something together wrong. Have to take it all apart again. Seems like these builds are 1 step forward and 5 back. I ordered a cam for the engine and that arrived broken in half. Went to Advance auto and asked for a Holley 650 cfm carb for a spread bore manifold. Got it home and went to install it and it was a square bore carb and they didn't have a spread bore in stock so I had to order 1 from Jegs. Now I have all the right parts to do the engine.
