    Upholstery information
    Truxx1956
    Post  Truxx1956 on Fri May 08, 2009 4:53 pm
    Hey guys/gals, I'm an upholsterer by trade and I also build custom cars/trucks as a side job. I just wanted to say hi, and also if anyone needs any advice on interior planing and construction that I'd be glad to help. Interiors much like a frame or any other part of a hotrod, needs to be planed correctly from the beginning. There are some Do's and Dont's that we all need to know. As soon as I get some more time, I'll post some pics of our work from our shop. cheers
    Re: Upholstery information
    Post  Darkside Dave on Fri May 08, 2009 9:11 pm
    Thanks Terry,
    I was hoping you would be planning something along those lines.
    Truxx1956
    Post  Truxx1956 on Fri May 08, 2009 9:13 pm
    Yeah, I'm kind of busy these days, but I am available for question and such. I will try to get some pics on for you guys.
    low54
    Post  low54 on Wed May 13, 2009 1:40 pm
    This may come across naive but, Can you slpit the original bench seat from '54 f-100? My frame is in great condition, but I like the option of the split seat like the one below...
    Truxx1956
    Post  Truxx1956 on Wed May 13, 2009 7:58 pm
    Hey man, yeah you can if you can weld. All you got to do is strip down the seat to the bare metal frame and leave the backrest to the bottom so it will hinge. Then you will have to make a center pivot and cut the backrest in half. You'll of course have to have everything centered and all. I always recommend to throw away the springs and put a piece of plywood or steel plate to the bottom and back and use a good grade of foam instead of springs. One more thing on the backrest spliting. Weld 2 uprights top to botton in the center of the frame with only about 1/2" between them leaving them longer than the bottom crossbar so you can use them for your pivots I'd make them out of 1" square tubing (light gauge).
    I hope you understand this? If not, dont hesitate to ask.
    Post  tomget on Thu Oct 08, 2009 9:51 am
    Hi Terry
    I was wondering about the foam instead of springs you mentioned. Where can I find upholstery supplies like the foam and whatever else I might need. I've got an funky F1 seat and the frame is good, but the springs are broken here and there and rusty too.
    Truxx1956
    Post  Truxx1956 on Thu Oct 08, 2009 1:20 pm
    Hey Tom, I dont know where you live, but we get most of our supplies from a place called The Miami Corp. They are in Ohio and do have a retail store. I think they are themiamicorp.com on the web? I'm not sure as we dont order online . They have different densities of foam and stuff. You need to make a plywood pan or metal for the bottom of the seat after removing the springs and then use a hard (S95) foam for the bottom and then softer foam for the top of it. That way it is soft on top and firm on the bottom so you can sit along time on the road. My personal email is trucks1956@yahoo.com I got to go back to work right now so if you need anything else. Feel free to email me
    GOD bless
    Post  tomget on Thu Oct 08, 2009 5:54 pm
    Hi Terry
    I live in Northern California--napa county--and yes I was hoping for an on line source, and thanks i'll check out the on line for S95 foam and softer for the back etc. I've got an extra frame and an existing reupholstered bench seat that someone before me did--and they just didn't get it too my liking. I used it for awhile, but found a good OEM replacement that looks and works fine. But I was thinking of rebuilding the other. Its like they filled the back with too much "whatever" and it kinda forces one into the steering wheel etc and also the bottom is not well supported such that it slumps badly on the drivers side. The slumping on the drivers side is probably a common problem. I haven't taken it apart its one of the projects that is in the Q but I hope to get to it someday, And I have another==with the bad springs etc so Its good to know I can rebuild the thing. The frame is good=just fine-but the springs are broken etc--its toast in my opinion.
    Thanks for your help
      Current date/time is Tue Jun 19, 2018 8:05 am
