    Chopped 55 F100
    Chopped 55 F100 - Page 3 Empty Re: Chopped 55 F100
    Post  Darkside Dave on Mon Mar 26, 2012 8:47 pm
    Cool Man !!!
    Until I saw you post I hadnot considered the size press you would need for that job. Did it really have to be that big or was that what was available?
    BTW, on another subject, machining aluminum, a good machinist friend of mine turned me onto something interesting. He said he has been very successful at using 1/2" shank Carbide router bits to machine aluminum on his Bridgeport mill. I had a few and tried it. It works. The point is that they are cheap and you can get about any style and shape you want from Grizzly.
    Duke55
    Duke55
    Post  Duke55 on Tue Mar 27, 2012 9:33 pm
    Darkside Dave wrote:
    Cool Man !!!
    I definitely did not need a press this big. For 18 gauge steel it take 1.8 tons per inch of shear, so about 22 tons to press my 12" louvers. A 22 ton press is easy to come by but one that can accept a 4-5' wide sheet with precision placement of the dies is not. The smallest precision press brake I have seen is a 6' wide 50 or 100 ton press. Prior to locating this monster press I was seriously considering building my own press to get the job done (glad I found one to use instead).
    As for using router bits on aluminum I hadn't thought of that. I will definitely dream up a couple of uses for them. Thanks for the idea.
    Post  Darkside Dave on Wed Mar 28, 2012 6:49 pm
    If I remember correctly, you use a mist type coolant. I can't say if that will work well with the aluminum and the router bits as I use liquid coolant. However, that may not be a concern as you have used the mist system to machine aluminum. As for building a press, I think you are better off doing it the way you did. A one time use would probably nor justify building one.
    Duke55
    Duke55
    Chopped 55 F100 - Page 3 Empty LOTS OF LOUVERS
    Post  Duke55 on Sat Apr 14, 2012 10:52 pm
    True Mom and Pop shop. The first picture shows me the owner of the shop and his wife pressing louvers (great people). There are 85 louvers each spaced 1" apart. All the other pictures show the sheet setting on the truck.
    Chopped 55 F100 - Page 3 IMG_7702
    Chopped 55 F100 - Page 3 IMG_7703
    Chopped 55 F100 - Page 3 IMG_7705
    Chopped 55 F100 - Page 3 IMG_7706
    Chopped 55 F100 - Page 3 IMG_7707
    Chopped 55 F100 - Page 3 IMG_7708
    Post  Darkside Dave on Sun Apr 15, 2012 9:54 am
    I'm guessing the nerve racking part is bending it down over the back and hoping something doesn't bow or kink.
    Duke55
    Duke55
    Chopped 55 F100 - Page 3 Empty Excuses
    Post  Duke55 on Mon Jul 23, 2012 11:35 pm
    3 months later and no progress on the truck. I feel bad for not posting so I will post what I have been doing. I decided to stop working on the truck to finish my shop. I was in the process of building the shop when my dad passed away, then I lost all ambition on the shop and decided to finish this chopped 55 for him. Originally I planned to use my dads shop to paint the truck but after thinking through the project I decided the number of trips I would have to take to his shop that is 2.5hrs away was just too much. In the last 3 months I have completed the wiring, insulation, siding, hanging drywall, ran water/power and started mud and taping (also put in curbing and sod between my house and shop). The shop is 44' wide x 32' deep x 11.5' ceiling it has 2 10x10' and 1 10x12' overhead doors. I framed a 15x26' semi down draft paint booth in one of the bays. Other than that, I picked up a Logan 11x36 Powermatic lathe that I am just starting to play with. Definitely anxious to start working on the truck again.
    Post  Darkside Dave on Tue Jul 24, 2012 9:12 pm
    Hey Man...
    I too have not done a damn thing for three months. I just haven't been in the mood I guess. However, I'm starting to get the itch. You'll get no criticism from me.
    Chopped 55 F100 - Page 3 Empty Doing???
    Post  58 ford on Sun Jul 29, 2012 8:01 am
    I to have been busy with other peoples projects,So mine has been lacking also!!
    I have been watching a few of the builds and this one is going quite well.
    Thats the thing about this HOBBY we forget sometimes that it is, and when it becomes a job it is time to take a break!! I still have plans to have my 65 running by the end of september will see how it goes lol!!
    Duke55
    Duke55
    Chopped 55 F100 - Page 3 Empty Wheel spikes
    Post  Duke55 on Mon Sep 03, 2012 7:24 pm
    Finally worked on the truck for a day and it felt good. Yesterday would have been my dad's 56th birthday, so it just felt right to work on his truck. I picked up some 2.75" aluminum bar stock to make some new center caps for the wheels. This is what I came up with.
    Chopped 55 F100 - Page 3 IMG_8499
    Chopped 55 F100 - Page 3 IMG_8507
    Chopped 55 F100 - Page 3 IMG_8508
    I still need to make the mounting plates for the back side and sand a polish them, but I think they fit the truck well.
    I need to find 3-4 good days to work on my shop then it will be ready for paint. After paint i need to install the electrical fixtures, finalize the ventilation system on the paint booth, install the gas furnace and plumb the air lines. Never a dull moment.
    Duke55
    Duke55
    Chopped 55 F100 - Page 3 Empty Shops finally done and I am back to work on the chop truck
    Post  Duke55 on Fri Jan 04, 2013 5:00 pm
    Shop and paint booth are finally finished, truck moved out of the garage and into the shop and I am back working on it (this took much longer then I ever expected, but it is going to be nice).
    Few pictures of the semi-downdraft paint booth:
    Exhaust filters in front wall
    Chopped 55 F100 - Page 3 RoyceiPodPictures079_zps73d6879d
    Intake filters is rear ceiling
    Chopped 55 F100 - Page 3 RoyceiPodPictures078_zpsf1b85579
    Recessed wall lights behind glass
    Chopped 55 F100 - Page 3 RoyceiPodPictures077_zps5a176d91
    24" Tube-axial exhaust fan
    Chopped 55 F100 - Page 3 RoyceiPodPictures076_zps41c86acc
    Outside of booth front wall, exhaust ducting/mixing bench
    Chopped 55 F100 - Page 3 RoyceiPodPictures074_zpsc1e0e55c
    Front wall of work bays
    Chopped 55 F100 - Page 3 RoyceiPodPictures083_zpsc60f779f
    Chopped 55 F100 - Page 3 RoyceiPodPictures080_zps832bd4eb
    I then designed and built a metal roller to roll some angle iron for the paint booth ducting and the square tubing needed for the tonneau cover.
    Chopped 55 F100 - Page 3 RoyceiPodPictures084_zpsb2fa4d53
    Chopped 55 F100 - Page 3 RoyceiPodPictures087_zps08c575c6
    One of the completed rails for the tonneau cover
    Chopped 55 F100 - Page 3 RoyceiPodPictures125_zps93fa7129
    The original tonneau cover frame
    Chopped 55 F100 - Page 3 RoyceiPodPictures129_zps472d6472
    Modified tonneau cover frame for louvers
    Chopped 55 F100 - Page 3 RoyceiPodPictures131_zpsedaf451a
    Modified frame and louvered panel primed.
    Chopped 55 F100 - Page 3 RoyceiPodPictures136_zpsa13491c8
    Chopped 55 F100 - Page 3 RoyceiPodPictures137_zps05a048de
    Tonneau cover panel tack welded in place. It rolled very smooth with no buckling at the louvers.
    Chopped 55 F100 - Page 3 RoyceiPodPictures139_zps77b111d8
    Chopped 55 F100 - Page 3 RoyceiPodPictures140_zpsb69862a7
    First paint job out of the booth. I built it for my daughter for Xmas and gave it a lace paint job (fabricated everything except the door).
    Chopped 55 F100 - Page 3 RoyceiPodPictures103_zpsb3d5e075
    Chopped 55 F100 - Page 3 RoyceiPodPictures108_zps519bf2b1
    Chopped 55 F100 - Page 3 RoyceiPodPictures105_zpsa0003b11
    2nd paint job 2 days later (7 degrees outside and no issues keeping the booth warm). Shell for my truck.
    Chopped 55 F100 - Page 3 RoyceiPodPictures110_zpse0d6414e
    Chopped 55 F100 - Page 3 RoyceiPodPictures112_zps31355306
    Sorry for the long post, but I think I am all caught up now and will try to post more regularly. Also, did'nt want anyone to think I have just been slacking off.
    Duke55
    Duke55
    Post  Duke55 on Mon Mar 04, 2013 12:31 am
    To see the latest progress on the truck click on the following link.
    http://www.garagejournal.com/forum/showthread.php?t=183844
      Current date/time is Wed Jun 26, 2019 8:31 am
