    LOOKING FOR STUFF...
    Post  Darkside Dave on Tue Mar 23, 2010 12:00 pm
    I'm looking for '89 to '97 T-Bird and Cougar independent rear suspension systems complete with disc brakes, differential and everything. Also found in Lincoln Mark 8's after '90 I believe.
    I travel the Eastern U.S. primarily through Ohio, WV, VA, NC, SC, FL, GA, TN, & KY. If I am dead heading back with an empty trailer I can snag something down there if I know where it is and it can be winched into the trailer. I am willing to buy whole cars and in a lot of cases I don't care about a title unless it is something worth fixing and putting back on the road.
    Re: LOOKING FOR STUFF...
    Post  wmjoe1953 on Tue Mar 23, 2010 12:10 pm
    I know where two of them complete rears are, but you'ld have to come to Oregon to get them. You really need to be closer.
    1953 Ford F-750 semi: 6-71 Detroit with 9 speed Road Ranger on air leaf suspension
    Check it out @ photobucket:
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1953%20F-750/
    1963 Ford Falcon Futura 2dr Sedan: Finished, and SOLD
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1963%20Futura/
    1954 F-100: Ground up Restoration
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1954%20F-100%20project/
    Post  Darkside Dave on Tue Mar 23, 2010 2:33 pm
    wmjoe1953 wrote:I know where two of them complete rears are, but you'ld have to come to Oregon to get them. You really need to be closer.
    No, what I really need is for them to be closer to me. But hey, it never hurts to put out the word. You never know...
    Post  55f350 on Tue Mar 23, 2010 8:47 pm
    dave i got an irs outta that 91 here i dont think im gonna be using . it's drums though not discs , but you can go to oreillys and buy everything needed to put discs on . also the mustang cobras use this irs but it's hubs , which are a direct bolt on , are 5x41/2 vs. the birds 5x41/4 . and the stang uses a 31 spline diff / axles . the mark8's had aluminum carriers , a arms that saved 17 lbs per side , and have a 3.27 r&p standard whereas most birds had a 3.08 . make me an offer . by the way the wheels and tires stay , as i need 'em for my bird . the whole sub and all is here it's all still bolted together . as you prolly know it damn near bolts into our 53-56 trucks frame rails . you only have to tweek the front mounts slightly and boom it's in . the track width is even correct for the trucks . beware the v-6 irs's as they are based on the 7.5 center section , not the 8.8 like the v-8 cars , and not as strong . let me know . later !!!!!!!!!!!
    Post  Darkside Dave on Tue Mar 23, 2010 9:41 pm
    Hi Kevin,
    I'll have to let you know and it depends on my having any runs out your way. There is also a '97 Mark 8 being parted out nearby. Thanks for replying though. This is what's great about having a small board where everyone kind of knows everyone else and where they are.
      Current date/time is Thu Jan 17, 2019 1:25 am
