    55 f-100, let no panel be unmodified!
    55 f-100, let no panel be unmodified! Empty 55 f-100, let no panel be unmodified!
    Post  charger on Fri Jan 08, 2010 6:09 pm
    start posting some of my build pics, had pictures when i bought it but for some reasons they disapeared (wife was fooling around with my stuff again!!, anyway first picture is with the crown vic front end welded on
    55 f-100, let no panel be unmodified! Dcp02411
    front end welding job (welds not cleaned up!)
    55 f-100, let no panel be unmodified! Dcp02412
    55 f-100, let no panel be unmodified! Dcp02413
    55 f-100, let no panel be unmodified! Dcp02414
    welder series 4 link set up
    55 f-100, let no panel be unmodified! Dcp02415
    55 f-100, let no panel be unmodified! Dcp02416
    55 f-100, let no panel be unmodified! Dcp02417
    using plumb line, determine center of axle,mark and reference to a rivet on frame to make sure marks are the same distance
    55 f-100, let no panel be unmodified! Dcp02418
    axle,spring perches removed
    55 f-100, let no panel be unmodified! Dcp02419
    crown vic rear end,tacked it to the bottom of the frame
    55 f-100, let no panel be unmodified! Dcp02420
    front spring perch was ripped out of the frame and re-welded, to repair and strengthen the frame i welded the 4 link brackets to a piece of angle iron i found lying around
    55 f-100, let no panel be unmodified! Dcp02421
    welded the angle to the frame,assembled and ready to go!
    55 f-100, let no panel be unmodified! Dcp02422
    55 f-100, let no panel be unmodified! Empty Re: 55 f-100, let no panel be unmodified!
    Post  charger on Tue May 04, 2010 1:16 pm
    dave, can you sticky this one as my build thread??
    Post  Darkside Dave on Mon Jul 19, 2010 6:35 pm
    Hi Charger,
    Sorry it took so long to get around to this but I finally made this thread a sticky as you requested.
    Post  charger on Tue Jul 20, 2010 1:19 pm
    THANKS! I`LL START ADDING ALL MY INFO ONCE I HAVE A BIT OF TIME
    Post  Darkside Dave on Tue Jul 20, 2010 5:03 pm
    charger wrote:THANKS! I`LL START ADDING ALL MY INFO ONCE I HAVE A BIT OF TIME
    It's no excuse but I sometimes miss stuff. In the future you should just e-mail if you need something like this. I feel bad about missing your request.
    Post  charger on Sat Jul 24, 2010 9:08 am
    wanted the truck to go lower and really had no room for the bags so i fabricated this rear bag bracket,1st thing i did is measured and marked both sides of the frame equally, found myself a piece of used pipe that would be the right size for my c-notch,cut it to the frame width and cut it in half,tacked each half to the inside of the frame,cut out around the c-notch and welded it up, for the bags i decided to mount them on top of the rear end,found some 1/4 inch plate,measured where my bags would sit(height wise) and cut 2 pieces of plate out,welded them to both inner sides of the frame, i then cut out 2 pieces of pipe,welded my bag mounts to them and then welded them to the plates, for the rear end bag mounts i took 2 pieces of plate and welded them to the rear end allowing room for my bag mount bolt,then welded the bag mount to the plate,and i believe that was it!
    55 f-100, let no panel be unmodified! Pictur16
    https://i.servimg.com/u/f31/14/01/27/98/pictur14.jpg
    55 f-100, let no panel be unmodified! Pictur17
    55 f-100, let no panel be unmodified! Pictur19
    55 f-100, let no panel be unmodified! Pictur18
    Post  charger on Sat Jul 24, 2010 9:17 am
    decided to box in my frame for a cleaner look, already had it partially boxed in at the front due to the suspension swap, the rear end was c-notched and partially plated with 1/4 inch steel, i ran 1 1/4 inch conduit tubing inside the frame only welding it at 3 places in case of chassis flex, then i started to plate the sides up,bent up pockets so i can get to my bed mounting bolts, for the rear, i`m using a 69 mustang tank so i made my bracket up and welded nuts inside the frame to attach the tank frame,needed more side room for the tank so i cut the bottom of the rails enough to clear the tank,didn`t have anything fancy to bend the steel in the back frame so i welded the top plate to the frame, heated it up and bent it into a oval shape and then welded the bottom to the frame.
    55 f-100, let no panel be unmodified! Pictur20
    55 f-100, let no panel be unmodified! Pictur21
    55 f-100, let no panel be unmodified! Pictur22
    55 f-100, let no panel be unmodified! Pictur23
    55 f-100, let no panel be unmodified! Pictur24
    55 f-100, let no panel be unmodified! Pictur25
    55 f-100, let no panel be unmodified! Pictur26
    55 f-100, let no panel be unmodified! Pictur27
    55 f-100, let no panel be unmodified! Pictur28
    Post  charger on Sat Jul 24, 2010 9:30 am
    Got my tank done this weekend and i figured i`d post it up, first of all bought a 69 mustang tank off e-bay (cheepest around) cut the fuel pump and vent bung off the crown vic tank, measured and marked a hole where the tank is completely flat at the bottom and cut a hole on top of the tank with a holesaw,didn`t have the proper size so i just cut out the hole to the proper size, was initially going to build a fuel tray like tanks ink are using to mount on my fuel pump but decided to build a sump and baffle (don`t want the pump to ever starv out) figured out my sump would stick out one inch lower than my tank and a 2 1/2 wall or baffle inside the tank, proceded and bent and welded my sump,(kinda looks like a ashtray) ,drilled 6 holes just over the 1 inch mark so fuel can go into it (front and front sides only), 1/4 inch from the top curled in the edges,on the front and front sides,centered it in the pump hole of the tank, marked and cut the bottom of the tank out,GRIND THE TANK STEEL TO REMOVE GALVANIZED COATING BEFORE WELDING) welded in the sump, inside and outside of the tank, welded in the bungs, fuel pump was sitting sideways from the bung mount, cut the mounting bracket off and added a piece of steel and welded it together to make it straight and also the proper length from the bottom of the tank to the top, so now all i have to do is line the inside of the tank and its done!! going to use kreem tank liner
    55 f-100, let no panel be unmodified! Dcp02710
    55 f-100, let no panel be unmodified! Dcp02711
    55 f-100, let no panel be unmodified! Dcp02712
    55 f-100, let no panel be unmodified! Dcp02713
    55 f-100, let no panel be unmodified! Dcp02714
    55 f-100, let no panel be unmodified! Dcp02715
    55 f-100, let no panel be unmodified! Dcp02716
    55 f-100, let no panel be unmodified! Dcp02717
    55 f-100, let no panel be unmodified! Dcp02718
    55 f-100, let no panel be unmodified! Dcp02719
    55 f-100, let no panel be unmodified! Dcp02720
    55 f-100, let no panel be unmodified! Dcp02721
    55 f-100, let no panel be unmodified! Dcp02722
    Post  Darkside Dave on Sat Jul 24, 2010 9:36 am
    Hi Charger,
    I like what you did with your tank. I may have to do something like that myself if I can't find a late model one with the F.I. pump built in that will fit. Greta job with all the pictures...
    Post  charger on Sat Jul 24, 2010 9:38 am
    pics of my homeade box
    55 f-100, let no panel be unmodified! Pictur29
    55 f-100, let no panel be unmodified! Pictur30
    55 f-100, let no panel be unmodified! Pictur31
    55 f-100, let no panel be unmodified! Pictur32
    55 f-100, let no panel be unmodified! Pictur33[quote][code]
    55 f-100, let no panel be unmodified! Pictur34
    55 f-100, let no panel be unmodified! 100_3510
    55 f-100, let no panel be unmodified! Pictur39
    Post  charger on Sat Jul 24, 2010 9:44 am
    some pictures while were were chopping the top
    55 f-100, let no panel be unmodified! Pictur35
    55 f-100, let no panel be unmodified! Pictur36
    55 f-100, let no panel be unmodified! Pictur37
    55 f-100, let no panel be unmodified! Pictur38
    55 f-100, let no panel be unmodified! 100_3511
    55 f-100, let no panel be unmodified! 100_3910
    55 f-100, let no panel be unmodified! 100_3911
    Post  Darkside Dave on Sat Jul 24, 2010 10:44 am
    You're a brave man Charger... I gave that idea some though but I chickened out as there was way too much to do otherwise on my project. I do applaud your ambition and initiative though. Pleas keep us posted with your progress. BTW, how long have you been on this project by now???
    Post  charger on Sat Jul 24, 2010 12:26 pm
    it will be 2 years this coming winter, most of the work was done the first year
    Post  charger on Wed Oct 27, 2010 1:10 pm
    kicked the old bucket of bolts out of the garage this weekend, figured i`d take a few pictures, wasen`t happy with the looks, started to do some measuring and my box in the front has to go up a slight bit approx 1/4 inch, also from the pictures seems like the cab needs to be raised in the back??? any other critiques??? working on some lighting and probably next weekend going to start working on the truck again, fighting the fit and finish stuff right now, my passenger door opening on the back side is 1/4 inch bigger than the drivers, going to make a 90 degree plate and weld it into the chanel to bring down the gap, i think this truck was built on a friday or monday! never seen one this bad! went to the wreckers on the weekend picked up some goodies off a 1992 t bird, shifter, electric fan and newer style altenator, going to take apart the shifter and modify it with a longer shaft similar to a genie or lokar.
    55 f-100, let no panel be unmodified! 100_4110
    55 f-100, let no panel be unmodified! 100_4111
    55 f-100, let no panel be unmodified! 100_4112
    55 f-100, let no panel be unmodified! 100_4123
    55 f-100, let no panel be unmodified! 100_4119
    55 f-100, let no panel be unmodified! 100_4120
    Post  Darkside Dave on Wed Oct 27, 2010 2:06 pm
    Looking Good Man...
    I know the drill when it comes to making stuff fit. I'm in the worst of that now. Ny son thinks my electrical stuff will be the big problem but I think what I'm thrying to get through now is the worst of it. Every time I think I have it all figured out something is in the way and needs modified or moved. I know the drill... I think your project is looking good and in the end it will all come togehter only because you will not settle for less.
    Keep up the good work Man...
    Post  carnut122 on Thu Jan 13, 2011 3:28 pm
    Charger,
    That's looking good!
      Current date/time is Sun May 19, 2019 6:56 am
