    Differential Gear Ratios / Pinion Gear Ratio Calculator
    Post  Grumpyoldman on Mon Dec 07, 2009 5:31 pm
    In this calculator, we are dividing the number of teeth on the pinion gear by the number of teeth on the ring gear. There are also several ways to determine the ratio manually even if you can't see the number of teeth on the ring gear or pinion.
    http://www.csgnetwork.com/rnggrpinioncalc.html
      Current date/time is Sun Mar 24, 2019 1:26 pm
