    Engine Specs Database
    Engine Specs Database Empty Engine Specs Database
    Post  Grumpyoldman Tue Dec 01, 2009 10:52 pm
    BoxWrench Engine Specs Database
    There are three main concepts that need to be understood before doing most engine assembly, re-assembly or basic engine tune-up work. The layout of Cylinder Numbering is different across the mojor makes of automobiles. The Firing Order is extremely various when you compare engine types even within the same automotive manufacturers engine families. It is also critical to engine work to know the Distributor Rotation Direction for the Distributor Rotor beneath the Distributor Cap.
    http://www.boxwrench.net/specs_index.htm
      Current date/time is Fri Apr 26, 2024 11:11 pm
