    frenched tail lights
    frenched tail lights Empty frenched tail lights
    Post  charger Fri Nov 27, 2009 5:23 pm
    what do you do when you have no money and want to get a project done and you have 2 minty crown vic tail lights!! well....
    frenched tail lights 100_3719
    frenched tail lights 100_3720
    let the carnage begin!! will post more after the weekend when there finished!
    frenched tail lights Empty Re: frenched tail lights
    Post  charger Mon Nov 30, 2009 10:26 am
    here we go, after cutting the back off the light, the plastic chrome rim comes off, make your pattern of the light you choose, trace it on plywood of mfd and cut the shape out with a jigsaw without damaging the outside of the shape, cut a strip of steel 1 inch wide, insert into the plywood shape and bend it to conform this shape, cut to length and weld the ends together (french insert??) , next take a piece of plate wider and longer than your insert, trace your shape and cut out the center,weld this plate to your insert, measure and cut out the lens to fit, next i made a light bucket just a hair wider than the insert, drilled and die grinded a hole for a light socket, this is how it fits together, you put the lens between the flat plate and your light bucket, drill holes through all three and fasten with screws, now if your lens is not 100% flat you can also use a heat gun to straighten the lens, cut a hole in your roll pan the same size of your insert, give yourself a little gap and weld in place, the packing plate of the insert can be trimmed and welded the rear box beam, spray paint the inside of the light bucket a bright silver, install a regular or led bulb and your ready to go! as you can see i didn`t quite finish the welding, ran out of wire!!!
    frenched tail lights 100_3721
    frenched tail lights 100_3722
    frenched tail lights 100_3723+
    frenched tail lights 100_3724
    frenched tail lights 100_3725
    frenched tail lights 100_3726
    frenched tail lights 100_3728
    frenched tail lights 100_3729
    frenched tail lights 100_3730
    frenched tail lights 100_3731
    frenched tail lights 100_3732
    frenched tail lights Empty Nice work...
    Post  Darkside Dave Mon Nov 30, 2009 4:09 pm
    Once again I see the true mark of a Darksider here... That's the kind of stuff I like to see. I love it when people go out and find stuff from donors to modify and incorporate into their project. There's got to be a lot more pride and sense of accomplishment in something like this as opposed to just ordering up a catalog part that is in all likely hood made in China.
    Great Work...
      Current date/time is Fri Apr 26, 2024 5:04 pm
