BoxWrench Engine Specs Database
There are three main concepts that need to be understood before doing most engine assembly, re-assembly or basic engine tune-up work. The layout of Cylinder Numbering is different across the mojor makes of automobiles. The Firing Order is extremely various when you compare engine types even within the same automotive manufacturers engine families. It is also critical to engine work to know the Distributor Rotation Direction for the Distributor Rotor beneath the Distributor Cap.
http://www.boxwrench.net/specs_index.htm
