    Leading a welded seam
    Post  wmjoe1953 on Tue Sep 01, 2009 2:15 am
    I got a '54 Ford truck grille from a friend, and it needed new ends. I robbed a pair off a '55 grille I had, and welded them onto the '54 center section. I didn't want to gob it all with bondo, so I thought about how to do it for a while. I then remembered being shown how to lead in a seam when I was younger, and also remember seeing it done on T.V. So, I gave it a shot. I ground out the welds to a slight concave surface. I then got out my rose bud torch tip, and set a medium low flame. I slowly warmed the back side of the grille, just until the leading melted. I used 1/8" acid core solder, and it worked great. I pooled the solder into the work area, until it was well over the needed height. I then was able to take a coarse scotch brite disk on my angle grinder, and use it to smooth out the solder. I worked it with light pressure until it macthed the headlight housing, and the grille center section. I then finish it off with 80 grit sand paper until it took on a prepped metal appearance. I was able to finish the work piece off with a very light coating of EverCoat glaze and sanded it out with more 80 grit. There are several pictures in my photobucket album.
    1953 Ford F-750 semi: 6-71 Detroit with 9 speed Road Ranger on air leaf suspension
    Check it out @ photobucket:
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1953%20F-750/
    1963 Ford Falcon Futura 2dr Sedan: Finished, and SOLD
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1963%20Futura/
    1954 F-100: Ground up Restoration
    https://s248.photobucket.com/albums/gg164/wmjoe1953/1954%20F-100%20project/
    Re: Leading a welded seam
    Post  wmjoe1953 on Tue Sep 01, 2009 2:20 am
    So, to finish my thread topic. After priming it, I sanded that out with wet 220 grit. I dried it all off, washed it down, and shot it with a coat of Dupli-Color Acrylic Enamel gloss white. I let that dry and sanded that out with 400 grit wet. I then finished it off in the Dupli-Color white. The finished grille isn't museum perfect, but it could pass in a car show, and is way better than driver quality. It will be going on my '53 Big Job this weekend, and it will be getting titled as a '54. I wanted to get it pinked 3 weeks ago, but haven't gotten the chance since. Hopefully soon though. Take a look at the newest pictures in my photo bucket album. There are now over 250 pictures of my truck build in there.
    Boilermaker
    Boilermaker
    Futura with big plans
    Post  Boilermaker on Tue Nov 16, 2010 9:13 pm
    What a project. That looks like quite a job and the results speak for themselves. What front suspension components did you use? A T-5 transmission should get the job done. Too bad you didn't paint the underside while it was apart but it looks very nice as is. Great job.
      Current date/time is Sun Mar 24, 2019 1:16 pm
