    1935 Ford 1 1/2 ton
    Anonymous
    Guest
    Guest
    1935 Ford 1 1/2 ton Empty 1935 Ford 1 1/2 ton
    Post  Guest Wed Jun 17, 2009 7:08 am
    I have a 35 that came with no engine.
    I have too many projects and have been planning to keep this as simple and cheap as possible.
    The plan is to use the adapter to put a smallblock Chev against the original transmission.
    It needs a new glass for the windshield and a few electric wires to make it go.
    The brakes are mechanical and should work with a minimum of repair.
    The truck will be driven locally, no Interstates, no high speed, no need of fancy modern parts.
    The paint is original and kinda ratty but is serviceable.
    There you have it!
      Current date/time is Fri Apr 19, 2024 7:19 am
