    Better Than Sliced Bread??
    Better Than Sliced Bread?? Empty Better Than Sliced Bread??
    Post  Lowlid Thu Jun 18, 2009 4:57 pm
    I dropped by a friends shop a short time back and he was mixing up some high build primer. Now mixing up primer might not be very exciting to some of you, but I come from back in the days of lacquer type primer, just open up the can, give it a good stir, pour it in a container, pour in proper amount of thinner, mix it up and ready to go. What you don't use, put a lid on the can and use it later. That last part you can't do with todays primers that use a catalyst. You can throw it in a fridge and extend the pot life a little but not much.
    So what you try to do is mix only what you need and use it or lose it. My friend had acquired one of the mixing lids used by your local paint supplier for his mixing station. They use a gear drive on top that is attached through the shaft to a mixing paddle. The lid has attaching tabs that secure it to the can and a pouring spout that is opened by thumb action and spring pressure closes it.
    Better Than Sliced Bread?? Paintproducts001
    Better Than Sliced Bread?? Paintproducts004
    He removed the guard over the gear and then the gear.
    Better Than Sliced Bread?? Paintproducts005
    Now all he has to do when he needs a little primer is grab a drill and run the agitator for a few minutes.
    Better Than Sliced Bread?? Shoppics
    Next he uses his thumb to slide the pouring spout open and pours himself exactly what he wants
    to mix up.
    Better Than Sliced Bread?? Buildpics112
    Neat, clean, and no wasted primer on paint mixing sticks or in the lip of the can or running down the side of the can or worse, spilled on the floor.
    If you do any amount of body work where you do a lot of priming, this is one of the best ways to dispense a small amount of primer that I've seen lately. He got the lid from his paint supplier for free because it had a broken gear on top. I assume that they don't sell replacement gears to fix them. (maybe not worth the trouble)
    I don't need to tell you that I had to have one and it is now resting peacefully on top of a brand new can of primer( that's it in the pictures), ready at any time to pour up any amount that I may need.
    Better Than Sliced Bread?? Empty Re: Better Than Sliced Bread??
    Post  havi Thu Jun 18, 2009 5:05 pm
    WOW!!! I want one!!
    56panelford
    56panelford
    Post  56panelford Wed Aug 26, 2009 8:46 pm
    How expensive are they and where can you buy them, I'm forever dumping some on my bench top, looks to be the best solution. Thanks for the tip.
    Post  charger Thu Aug 27, 2009 10:26 am
    buddy has the complete mixing system with lids like that verry slick! seen them on e-bay for cheap or sometimes you can get them used at paint supply stores for around 10-20 bucks
    Post  Lowlid Mon Aug 31, 2009 7:26 am
    charger wrote:buddy has the complete mixing system with lids like that verry slick! seen them on e-bay for cheap or sometimes you can get them used at paint supply stores for around 10-20 bucks
    Yeah, what Charger said.
    Check out your local paint supplier and see what they do with their lids when the gear on the top gets screwed up. That was how my buddy got his. They were going to throw it away and he grabbed it and took the gear off and started powering it with his drill. Works great!!! He has bought so much paint from his supplier over the years that his supplier gave him a couple new ones and I got one of them. Free is always good. Very Happy
      Current date/time is Wed May 08, 2024 12:56 pm
